Connecting VTL to Cloud Storage
keiransteele
Thu Mar 01, 2018 9:45 pm
I was told by your sales team that I could connect your VTL to Azure blob storage and our cloud providers S3 compatible block storage. I'm not able to find documentation on how to do this.
Thanks.
Oleg(staff)
Mon Mar 05, 2018 9:16 am
Hi keiransteele,
You can find the documentation here.
keiransteele
Wed Mar 07, 2018 10:42 pm
Thanks but that's not what I asked for. I doesn't relate to Azure or S3 compatible storage at all, it's specific to AWS S3.
https://www.starwindsoftware.com/starwi ... pe-library
You website clearly states that the VTL can backup to Azure object storage and the graphic shows that too as well as backing up to on prem object storage but it seems that no one knows how to do this. I have logged a support case and emailed your sales staff too that told me it was possible without a good answer.
Thanks.
Oleg(staff)
Thu Mar 08, 2018 2:00 pm
The improved functionality of StarWind Cloud VTL to be implemented alongside with Azure blob storage and S3 compatible block storage is currently under development.
StarWind representative will contact you regarding your environment configuration in the nearest time.
keiransteele
Thu Mar 08, 2018 6:17 pm
Thanks but I no longer need to be contacted regarding this. I wanted those two features and as they're not available although you have advertised them, then I'm no longer interested.
Thu Mar 08, 2018 11:58 pm
I really feel like I need to jump in here. First of all thank you for your super-dismissive reply! We really appreciate it. Second there are two options to offload VTL images to Azure:
1) Thru the Azure-exported SMB3 file share, so-called Azure Files, see https://azure.microsoft.com/en-us/servi ... rage/files for reference
2) Native support thru the BLOB
(1) option is working now, was working at the time you've been applying for demo or whatever you did to get hands over the software and it's not different from placing StarWind VTL images on your local SMB3 file server. Option (2) is currently in beta but we'll release it in a couple of weeks.
Good luck with your challenges and I wish you and your prospects a patience. Lots of it!
keiransteele wrote:Thanks but I no longer need to be contacted regarding this. I wanted those two features and as they're not available although you have advertised them, then I'm no longer interested.
brcstar
Wed Aug 22, 2018 3:23 am
Is there an update on this one?
I'm not able to connect to Azure Storage I receive 'Credentials are incorrect. parameters' Was successfully connected with backblaze but due to geographic issues the transfer is way way way to slow.
I have tried different clients, with different storages, I can't get this to work.
Do you have setup documentation? Please no need to send me the documentation here: https://www.veeam.com/blog/archiving-to ... d-vtl.html
The above one is not helpful.
Wed Aug 22, 2018 4:56 pm
Are you 100% sure the credentials you tried were correct ones? This question may sound a little bit irritating, but we need to make sure.
verloren22
Wed Apr 17, 2019 8:20 pm
Hi, I'm trying to configure cloud replication with azure blob storage and I'm getting the "Credentials are incorrect. parameters" error. Has support for blob been added? I'm on version 8.0.0.12767.
Oleg(staff)
Fri Apr 19, 2019 9:09 am
Hi verloren22,
Yes, it should work without issues. Please double-check your credentials.
kbtech
Wed Jan 08, 2020 9:20 am
Hi there,
I'm having the same problem, and i'm sure the credentials are correct, as i can connect using the Microsoft azure storage explorer installed on the same machine using the same details?
I'm using version 8.0.0.13279.
Any idea's, has anyone got this working or experienced the same problem and managed to resolve the issue?
Thanks in advance.
Cheers
Paul
Wed Jan 08, 2020 12:33 pm
Greetings Paul,
Could you kindly provide me with the logs? Here is the article on how to collect the logs: https://knowledgebase.starwindsoftware. ... collector/.
kbtech
Thu Jan 09, 2020 8:30 am
Thanks, I've got the log files output, but it seems to be too big to attached to the reply? Says it's more than 256KB, which it is, as it's 2984KB?
Cheers
Paul
Thu Jan 09, 2020 11:45 am
Please upload them to your file sharing service.
kbtech
Fri Jan 10, 2020 9:34 am
OK here is a link the file.
https://www.dropbox.com/transfer/AAAAAD ... alClaHmwKU
Cheers
Paul
