Starwind V2V Converter
jake2018
Tue Jul 31, 2018 6:36 pm
Looking to convert 60 VMs from VMWare to Hyper-V. Want to know if the software can convert multiple VMs at the same time or if it is a one-to-one conversion, as well as if the VMs have to be powered off or if this can be completed live.
Thank You,
Jake
Ardie
Tue Jul 31, 2018 6:46 pm
The GUI version appears to be single threaded, however this can be scripted using the command line utility: https://forums.starwindsoftware.com/vie ... =15&t=4459
Per the doc - https://www.starwindsoftware.com/resour ... -converter - VM's need to be powered down.
"Important note: StarWind V2V Converter does not support converting “on a fly” thus, the selected VM needs to be shut down first."
Tue Jul 31, 2018 7:24 pm
Exactly. This is the way it works.
Wed Aug 08, 2018 3:00 pm
OK, I'm moving this to the appropriate place.
