Rik
Tue Apr 28, 2020 7:30 am
Hello
I'm trying to convert a .imgc file to .vmdk file but imgc files are not in the list of supported files from the converter. I want to run the file in Virtual Box after i converted it.
Any suggestion?
Tue Apr 28, 2020 10:32 am
Greetings Rik,
Well, officially, V2V does not support that...
There is a trick you can try though. It seems to be a RAW image, so you can try renaming it to *.img and try converting it. Save a copy somewhere.
Let me know please if that works (or does not).
Rik
Tue Apr 28, 2020 1:06 pm
Hello
Thanks for your suggestion.
I renamed the file to .img and V2V was able convert it into .vmdk. It was not possible to run the file in Virtual Box probably because file was not recognized by Virtual Box?
Error message from Virtual Box Callee RC : VBOX_E_OBJECT_NOT_FOUND ( 0x80BB0001)
Rik
Tue Apr 28, 2020 3:59 pm
Hello Yaroslav
I got past previous obstacle thanks to the info in the links. Now the VM want start up . I get this message : FATAL : No bootable medium found! System Halted . The .vmdk file is in the correct folder so i guess the VM does not recognize it?
Rik
Thu Apr 30, 2020 8:29 am
Hello Yaroslav
I tried every suggestion in the links but nothing worked for me . Also resetting , restarting and reinstalling brings no cure.
