davidmatthewson
Mon May 18, 2020 12:58 pm
Hi
I've used the SW convertor in the past with good results and downloaded the current version to convert a P2V Windows 10 x 64 to ESX 6.7u3 system. It installed on the clean W10 box OK and seemed happy with the config to convert C$ and machine to ESX.
Started it off and the % stays at 0. An hour later I retried, same result. Log below, edited for GDPR.
The log file name: 'logs\V2V_Log-20200518-133154.log' (PID 9616)
5/18 13:31:54.742 2ac4 Facility ???INFO: CV2V_ConverterApp::InitInstance: SetDllDirectory: C:\Program Files\StarWind Software\StarWind V2V Converter\lib
5/18 13:31:54.742 2ac4 Facility ???INFO: CV2V_ConverterApp::InitInstance: File Version: 9.0.0.202
5/18 13:31:54.742 2ac4 Facility ???INFO: CV2V_ConverterApp::InitInstance: Load language IDR_XML_ENGLISH
5/18 13:31:54.742 2ac4 Facility ???INFO: CV2V_ConverterApp::InitInstance: Load language IDR_XML_RUSSIAN
5/18 13:31:54.742 2ac4 Facility ???INFO: CV2V_ConverterApp::InitInstance: Set current language English
5/18 13:31:54.758 2ac4 Facility ???INFO: CPS_V2V_Converter::CPS_V2V_Converter: Version MajorVersion 10, MinorVersion 0, BuildNumber 18363
5/18 13:31:54.758 2ac4 Facility ???INFO: WrapperHyperV::WrapperHyperV: LoadLibrary C:\WINDOWS\system32\wbem\wmiutils.dll - 973a0000
5/18 13:32:00.164 2ac4 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eTypeP2V
5/18 13:32:05.102 2ac4 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eVolumeSelectVM
5/18 13:32:19.977 2ac4 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eLocationTo
5/18 13:32:22.242 2ac4 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eESXConnectionTo
5/18 13:33:11.102 2ac4 Facility ???INFO: WrapperESXI::connect: m_url - [ ... ]
5/18 13:33:11.164 2ac4 Facility ???INFO: WrapperESXI::connect: fullName - Administrator xxxxx, key - xxxxx
5/18 13:33:11.195 2ac4 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eVMSettingsESX
5/18 13:33:23.742 2ac4 Facility ???WARNING: ESXiSelectFolderDlg::FillItemExpanded: HttpQueryInfo /folder?dcPath=ha-datacenter&dsName=LL-01 - 0. The operation completed successfully.
5/18 13:33:23.820 2ac4 Facility ???WARNING: ESXiSelectFolderDlg::FillItemExpanded: HttpQueryInfo /folder?dcPath=ha%2ddatacenter&dsName=LL-01 - 0. The operation completed successfully.
5/18 13:33:23.898 2ac4 Facility ???WARNING: ESXiSelectFolderDlg::FillItemExpanded: HttpQueryInfo /folder?dcPath=ha%252ddatacenter&dsName=LL-01 - 0. The operation completed successfully.
5/18 13:33:23.898 2ac4 Facility ???WARNING: ESXiSelectFolderDlg::FillItemExpanded: strTemp is empty
5/18 13:33:43.617 2ac4 Facility ???INFO: VMConverter::ESXIConverter::GetHostListInfo: ESX version: 6.7.0
5/18 13:33:43.648 2ac4 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eConverting
5/18 13:33:43.664 2084 Facility ???INFO: CPPConverting::Convert: InConvertType: 3, OutConvertType: 6
5/18 13:33:43.664 2084 Facility ???INFO: CheckFileESX::CheckFileExistance: /folder/Loki-C$/HDD2.vmdk?dcPath=ha-datacenter&dsName=LL-01
5/18 13:33:43.758 2084 Facility ???INFO: CheckFileESX::CheckFileExistance: state - 404
The 404 do not look good- where do I go from here pls?
Many thanks
David
davidmatthewson
Mon May 18, 2020 1:04 pm
OK, if I wait longer, I get a fail in the logs.
5/18 13:59:32.184 2084 Facility ???ERROR: WrapperESXI::Wait: response.returnval is null
5/18 13:59:32.184 2084 Facility ???INFO: VMConverter::ESXIConverter::CreateVM: createVM is false, Wait For Updates is fail
5/18 13:59:32.199 2084 Facility ???ERROR: CPPConverting::ConverterESX: Create VM Wait For Updates is fail
5/18 13:59:32.231 2084 Facility ???ERROR: CPPConverting::Convert: FAILED
All help much appreciated!
D
Mon May 18, 2020 4:07 pm
Hi davidmatthewson,
That's quite unusual error, I'd say.
Could you tell me how you filled Path to virtual machine field?
davidmatthewson
Fri May 22, 2020 11:43 am
OK, thanks for the replay & apologies for the late reply. I think the problem was me not the s/w. As the target I used the vCenter appliance IP and not the Host IP. So in terms of the target dir, I used 'browse' and then all I saw was the datastore, which I selected.
Using the Host and not vCentre as the target, I see dirs in the datastore and can select one.
If I do that, the conversion seems to run. The GUI now shows 'stuff' and the bar is at 2% - the logs show (sample) below which looks good.
5/22 12:34:17.763 35d0 Facility ???INFO: VMConverter::ESXIConverter::GetHostListInfo: ESX version: 6.7.0
5/22 12:34:17.879 35d0 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eConverting
5/22 12:34:17.889 36d0 Facility ???INFO: CPPConverting::Convert: InConvertType: 3, OutConvertType: 6
5/22 12:34:17.890 36d0 Facility ???INFO: CheckFileESX::CheckFileExistance: /folder/Loki/MyPC/HDD0.vmdk?dcPath=ha-datacenter&dsName=LL-01
5/22 12:34:17.933 36d0 Facility ???INFO: CheckFileESX::CheckFileExistance: state - 404
5/22 12:34:17.934 36d0 Facility ???INFO: CheckFileESX::CheckFileExistance: /folder/Loki/MyPC/HDD1.vmdk?dcPath=ha-datacenter&dsName=LL-01
5/22 12:34:17.958 36d0 Facility ???INFO: CheckFileESX::CheckFileExistance: state - 404
5/22 12:34:17.958 36d0 Facility ???INFO: CheckFileESX::CheckFileExistance: /folder/Loki/MyPC/HDD2.vmdk?dcPath=ha-datacenter&dsName=LL-01
5/22 12:34:17.982 36d0 Facility ???INFO: CheckFileESX::CheckFileExistance: state - 404
5/22 12:34:18.203 36d0 Facility ???INFO: VMConverter::ESXIConverter::CreateVM: createVM is true, 20
5/22 12:34:18.203 36d0 Facility ???INFO: CPPConverting::ConverterESX: Create VM 20
5/22 12:34:18.342 36d0 Facility ???INFO: CPPConverting::ConvertImage: pathInput: 0, pathOutput: [LL-01] Loki/MyPC/HDD0.vmdk
5/22 12:34:18.343 36d0 Facility ???INFO: P2V::CreateInputImage: path 0
5/22 12:34:18.343 36d0 Facility ???INFO: P2V::CreateInputImage: Size 0 - 400088457216, BytesPerSector - 512
5/22 12:34:29.324 36d0 Facility ???INFO: CPPConverting::ConvertImage: CreateInputImage: 0
5/22 12:34:30.487 36d0 Facility ???INFO: ESXVmdk::ParseFile: sFilename - [LL-01] Loki/MyPC/HDD0.vmdk
5/22 12:34:30.487 36d0 Facility ???INFO: ESXVmdk::ParseFile: m_cSSLThumbprint - A3:8F:10:75:A9:4D:B8:D7:EE:92:44:AF:73:90:D1:F8:FC:A7:B2:77
5/22 12:34:30.487 36d0 Facility ???INFO: ESXVmdk::ParseFile: m_cvmxSpec - [LL-01] Loki/MyPC/MyPC.vmx
5/22 12:34:31.128 36d0 Facility ???INFO: CPPConverting::ConvertImage: CreateOutputImage: 0
5/22 12:34:31.228 36d0 Facility ???INFO: P2V::getSectorsNext: countClusters - 12209680, dwCountBytes - 12209680
Many thanks - I'll update this when the conversion finishes.
D.
Fri May 22, 2020 12:19 pm
Great! Happy to know that.
Actualy, that would be one of the things we would check
Please make sure to convert the VM to the ESXi host. Keep us posted on this case.
davidmatthewson
Tue Jun 02, 2020 11:49 am
Sigh... ok, the convertor ran happily for about 8 hours - it was a few Tb of data - and them completed OK.
But.. when I tried to power up the new VM it failed to boot. Possibly I got the boot drive allocation wrong but had slightly lost the will to live to try again. So (sorry about this) I d/ld the VMWare convertor which did the job just fine and the new VM boots OK.
Thanks again for all your help.
Tue Jun 02, 2020 12:19 pm
Sorry to read that.
Could you share the converter logs? What exactly error did you encounter while trying to boot the VM? Was the conversion successful? Will be happy to learn about this conversion as many details as possible.
davidmatthewson
Tue Jun 02, 2020 12:35 pm
Thanks for the prompt reply. Yes, the conversion claimed to have run to 100% OK. I'll dig out the logs and share.
brgds
David
davidmatthewson
Wed Jun 03, 2020 11:14 am
Hi again.
OK, logs attached. This run converted OK it seems but when I powered up the VM it failed to boot. I don't have the full error as I didn't capture it but the on screen text referenced Grub which I thought was odd as it was a Windows 10 VM.
Hope that helps.
David
- V2V_Log-20200522-123145.7z
- Logs
- (1.79 KiB) Downloaded 1284 times
Mon Jun 08, 2020 4:40 am
The conversion was successful, so I do not think that there was an issue with V2V. I have just finished P2V conversion of my laptop to ESXi and was able to boot. That makes the question even more interesting.
If that was a GRUB-related issue, here might be a solution
https://communities.vmware.com/thread/617754.
Were there any Linux partitions on the source VM?
davidmatthewson
Mon Jun 08, 2020 3:22 pm
Thanks - interesting. The original Physical box was a Dell Precision PC which was 100% Windows and had never been exposed to Linux in any form. Thanks for the link - it does seem like the same issue in broad terms.
I've certainly used the Starwind convertor in the past with no issues so let's close the case and put it down to 'one of those odd things'.
Thanks again for all your help & great products! ;}
