command line helpl lsfs thin provision
travgonz
Fri Jul 24, 2020 7:27 pm
I am using the latest free version where I have command line administration only.
im trying to figure out the syntax to create a thin provisioned (lsfs) image file for starwind. anyone know how to do this? thanks
Sun Jul 26, 2020 4:47 pm
Greetings, could you can create LSFS using CreateHA_LSFS scripts from the C:\Program Files\StarWind\StarWindX\Samples\powershell folder. LSFS device is always thin provisioned. There is also a script for creating a standalone LSFS device.
Please make sure that your environment meets the LSFS requirements https://knowledgebase.starwindsoftware. ... scription/
