Tape Redirector Upgrade
maxxe74
Tue Aug 04, 2020 9:36 am
how can I check the latest version of Tape Redirector and compare to the one installed on my Server?
Also, how can I simply upgrade my installation without "affecting" any parameter? I am currently using "Tape Redirector V8"
Thanks for your support,
Max
Tue Aug 04, 2020 9:52 am
Greetings, if you have just requested and downloaded it recently, that is the latest version.
maxxe74
Tue Aug 04, 2020 10:04 am
Dear Yaroslav,
in effect I am using tape Redirector since a year now on my server and I have just installed the SW Management Console on my PC and I am trying to connect to the server but I get the following message:
"Console (v8.0.0.0 build 13586) and Service (v8.0.0 build 12767) build versions do not match. This can cause issues. PLease use the same build versions of console and service!"
I was thinking to update the software on my server but how can I safely update/upgrade it?
Max
Tue Aug 04, 2020 10:38 am
No worries. That means that you are running an old version of StarWind Service on the other server. Here is how to update StarWind VSAN https://knowledgebase.starwindsoftware. ... d-version/.
Let me know if there is anything else I can assist you with.
