Adding an additional disk
cre8toruk
Sat Jan 23, 2021 12:09 am
Hi All,
I need to add a quorum to my cluster can I add an additional disk and if so how.. Or should i simply create an SMB share somewhere and point it at that?
Kind regards,
Paul.
cre8toruk
Mon Jan 25, 2021 10:48 am
Ok, so I took a guess at rerunning the createHA2 script but this time changing the image name to Quorum and the size to something sensible (1GB).
The disk and sync process seemed to work fine but now my iscsi initiator won't connect and I have no disks.
I can see both disk images on both servers but clearly I've screwed something up. Can anyone advise what I need to do to add an additional disk ?
thanks in advance,
Paul.
Mon Jan 25, 2021 11:07 am
Please specify iSCSI discovery interfaces. Follow this guide https://www.starwindsoftware.com/resour ... rver-2016/
cre8toruk
Tue Jan 26, 2021 11:21 am
Hi, yes being thick! All sorted now thanks.
Tue Jan 26, 2021 1:52 pm
Thank you for the update. Let me know if you have additional questions.
