Error converting Hyper-V to Vmware
loubier_a
Wed Mar 24, 2021 4:55 pm
We have a problem when we try to convert a Vm from Hyper-V to Vmware : Starwind converter see empty disk.
We have a cluster hyper-v with 4 nodes which access to the storage on a Hyper-V cluster S2D trough SOFS Protocol (SMB3).
It's seems the tool can't access or see the sofs's shares :
Caption = "Get Virtual Disk Information";
Child = NULL;
CommunicationStatus = NULL;
DeleteOnCompletion = FALSE;
Description = "Getting Virtual Disk Information";
DetailedStatus = NULL;
ElapsedTime = "00000000000000.024648:000";
ElementName = "Get Virtual Disk Information";
ErrorCode = 32769;
ErrorDescription = "Failed to get the disk information.\n\n'': account does not have permission required to open attachment '\\\\clust-sofs\\sofs-ssd03\\VM\\SRW-VEEAMONE\\SRW-VEEAMONE.vhdx'. Error: 'General access denied error' (0x80070005). (Virtual machine ID )";
ErrorSummaryDescription = "Failed to get the disk information.\n\n Account does not have permission to open attachment.";
With the used account on the hyper-v host we can open the share.
Thanks in advance.
Best Regards
Thu Mar 25, 2021 10:22 am
Please try running conversion as administrator.
loubier_a
Thu Mar 25, 2021 3:42 pm
Hi even with the admin domain account i have the same problem.
Maybe the kerberos token is not transmitted to the S2D Cluster storage.
Best regards
Thu Mar 25, 2021 4:02 pm
It can be because we normally get those events when a user does not have the necessary privileges.
Are you using the latest V2V converter available, by the way?
loubier_a
Fri Mar 26, 2021 8:18 am
Yes i use the latest version 9.0.1.243
when i connect to the S2D cluster storage i see the SOFS's Shares but not with the compute cluster that accesses to the storage trough SMB3 and with kerberos authentication
best regards
Fri Mar 26, 2021 8:32 am
Can you please move the disk to the local storage?
loubier_a
Tue Apr 06, 2021 9:31 am
Sorry but we don't have enough free storage in local.
Tue Apr 06, 2021 10:20 am
Hi, can I have a look at the logs, please?
Will escalate this question to the R&D team.
