Will this work?
barney
Mon Nov 29, 2021 3:50 pm
Hi
Is it possible to install just the tape redirector on a system (I keep getting a link to the full starwind-v8 install & I'm unclear which option to select).
I intend to install it on a server that has a small scsi tape library attached to, but I intend to connect to it from a machine across a VPN in order to develop/debug code (I know it will be slow). Is this possible?
B
Tue Nov 30, 2021 4:21 am
Yes, this is OK. Please check this guide out https://www.starwindsoftware.com/resour ... edirector/.
You need to be connected to that tape device directly.
