Server 2019 and Old Dell 132T
assyrian47
Thu Dec 09, 2021 1:06 pm
Details:
Server: Dell R710 with LSI Logic 53c1030 OCI-X Fusion MPT SCSI card. No drivers available that work with card.
OS: Server 2019
Tape Library: Dell 132T with IBM Ultrium-TD3 Tape Device
From the Device Manager the SCSI card is show with Yellow Triangle Error: No driver installed.
Fact: SCSI is not supported on Windows Server 2019.
Made a 2012R@ VM in hopes I could use the StarWind VTL. The tape library is not recognized.
Any suggestions?
Thu Dec 09, 2021 2:14 pm
Hi, there is no luck to use the solution without the drivers. See the driver here https://support.hpe.com/hpesc/public/sw ... 8fe88dc9c6.
VTL does not work with the actual tape drives. See more about the solution at https://www.starwindsoftware.com/starwi ... pe-library
