"error read file"
Locked
Shotgun_Harry
Wed Dec 29, 2021 4:55 pm
Hi all, I have a laptop that no longer powers on but i believe the 1TB disk is ok. I would like to image the disk and boot the system into a virtual machine (Hyper-V, Virtual Box, VM ware - whichever is easiest and cheapest) as it has some software that is no longer available.
I have added the drive as a second disk to a desktop PC and can see 5 volumes. I am using an external USB drive to capture the image, and there is over 3.5TB free.
The problem i have is when i try to image the laptop drive (disk 1) the process starts, creates the VMDK file, says converting and then gives a "error read file' message. It also throughs up a "File Read Error!" prompt with retry or cancel the only options.
The log file shows the following
The log file name: 'logs\V2V_Log-20211229-162611.log' (PID 9592)
12/29 16:26:11.262 1bc0 Facility ???INFO: CV2V_ConverterApp::InitInstance: SetDllDirectory: C:\Program Files\StarWind Software\StarWind V2V Converter\lib
12/29 16:26:11.262 1bc0 Facility ???INFO: CV2V_ConverterApp::InitInstance: File Version: 9.0.1.268
12/29 16:26:11.265 1bc0 Facility ???INFO: CV2V_ConverterApp::InitInstance: Load language IDR_XML_ENGLISH
12/29 16:26:11.265 1bc0 Facility ???INFO: CV2V_ConverterApp::InitInstance: Set current language English
12/29 16:26:11.266 1bc0 Facility ???INFO: CPS_V2V_Converter::CPS_V2V_Converter: Version MajorVersion 10, MinorVersion 0, BuildNumber 18363
12/29 16:26:11.269 1bc0 Facility ???INFO: WrapperHyperV::WrapperHyperV: LoadLibrary C:\WINDOWS\system32\wbem\wmiutils.dll - 4ace0000
12/29 16:26:46.926 1bc0 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eTypeP2V
12/29 16:27:24.623 1bc0 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eHDDSelect
12/29 16:27:24.633 1bc0 Facility ???WARNING: PhysicalInfo::PhysicalDisksInfo::InitDisks: GetDiskFreeSpace \\?\Volume{7845324a-a657-41f1-99dd-648aa1e60565}\ fail - 87. The parameter is incorrect.
12/29 16:27:24.633 1bc0 Facility ???WARNING: PhysicalInfo::PhysicalDisksInfo::InitDisks: GetDiskFreeSpace \\?\Volume{e674dc54-8bee-48e6-beba-e37c803f2d28}\ fail - 87. The parameter is incorrect.
12/29 16:27:24.635 1bc0 Facility ???WARNING: PhysicalInfo::PhysicalDisksInfo::InitDisks: GetDiskFreeSpace \\?\Volume{6ae43069-d828-4275-a0b6-169c25515606}\ fail - 87. The parameter is incorrect.
12/29 16:27:24.636 1bc0 Facility ???WARNING: PhysicalInfo::PhysicalDisksInfo::InitDisks: GetDiskFreeSpace \\?\Volume{3db670f2-34bb-4035-8800-29ea35d1de03}\ fail - 87. The parameter is incorrect.
12/29 16:27:24.636 1bc0 Facility ???WARNING: PhysicalInfo::PhysicalDisksInfo::InitDisks: GetDiskFreeSpace \\?\Volume{abb988ba-6c3f-42b7-9e5f-bcaae4ba48c4}\ fail - 87. The parameter is incorrect.
12/29 16:27:24.648 1bc0 Facility ???WARNING: PhysicalInfo::PhysicalDisksInfo::InitDisks: GetDiskFreeSpace \\?\Volume{82c572cb-725c-4fc3-a17f-7dc65d065480}\ fail - 87. The parameter is incorrect.
12/29 16:28:15.318 1bc0 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eLocationTo
12/29 16:28:49.966 1bc0 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eFormat
12/29 16:29:11.870 1bc0 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eOptionsVMware
12/29 16:29:42.566 1bc0 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eOutputFile
12/29 16:30:41.702 1bc0 Facility ???INFO: CPPOutputFile::onNext: Out path: Z:\Starwinds-P2V\Lenovo.vmdk, Out format 3
12/29 16:30:41.702 1bc0 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eConverting
12/29 16:30:41.711 2438 Facility ???INFO: CPPConverting::Convert: InConvertType: 2, OutConvertType: 4
12/29 16:30:41.711 2438 Facility ???INFO: CPPConverting::ConvertImage: pathInput: 1, pathOutput: Z:\Starwinds-P2V\Lenovo.vmdk
12/29 16:30:41.711 2438 Facility ???INFO: P2V::CreateInputImage: path 1
12/29 16:30:41.711 2438 Facility ???INFO: P2V::CreateInputImage: Size 1 - 1000204886016, BytesPerSector - 512
12/29 16:30:49.149 2438 Facility ???INFO: CPPConverting::ConvertImage: CreateInputImage: 0
12/29 16:30:49.183 2438 Facility ???INFO: VMwareFile::NewFile: sFileName - Z:\Starwinds-P2V\Lenovo.vmdk
12/29 16:30:49.184 2438 Facility ???INFO: VMwareFile::NewFile: SectorType - 1953525168
12/29 16:30:49.184 2438 Facility ???INFO: VMwareFile::NewFile: EVMDKCreateType - 0
12/29 16:30:49.184 2438 Facility ???INFO: VMwareFile::NewFile: EVMDKAdapterType - 0
12/29 16:30:51.533 2438 Facility ???INFO: CPPConverting::ConvertImage: CreateOutputImage: 0
12/29 16:30:51.534 2438 Facility ???ERROR: CPPConverting::ConvertImage: Read 3
12/29 16:33:39.469 2438 Facility ???ERROR: CPPConverting::Convert: FAILED
I cant see any disk errors in the event log and i have made a backup of the disk to the USB drive using Easus ToDo.
Any help would be appeciated.
Thu Dec 30, 2021 3:11 pm
Thanks for your logs. We will have a look at them.
Tue Jan 04, 2022 6:01 am
Are you sure that the destination has enough free space?
Kruppmityu
Thu Apr 06, 2023 6:21 pm
Hi!
I recommend looking at this comment -> ( https://forums.starwindsoftware.com/vie ... ile#p34570 ), because my successful conversion log also contains lines like this:
The log file name: 'logs\V2V_Log-20230325-210155.log' (PID 6380)
3/25 21:02:01.607 3118 Facility ???WARNING: PhysicalInfo::PhysicalDisksInfo::InitDisks: GetDiskFreeSpace \\?\Volume{cd31bfe6-0000-0000-0000-50183a000000}\ fail - 87. A paraméter nem megfelelő. (The parameter is incorrect.)
3/25 21:02:01.609 3118 Facility ???WARNING: PhysicalInfo::PhysicalDisksInfo::InitDisks: GetDiskFreeSpace \\?\Volume{a9b01802-0000-0000-0000-d05074000000}\ fail - 87. A paraméter nem megfelelő. (The parameter is incorrect.)
3/25 21:08:20.168 8bc Facility ???INFO: CPPConverting::Convert: SUCCESSFULLY
Tue Feb 27, 2024 3:14 pm
Sounds like the issue is gone. Closing...
Tue Feb 27, 2024 3:15 pm
== thread closed ==
Locked
