Powershell + Starwind VSAN for Vsphere
kaderb
Thu Apr 14, 2022 1:59 pm
Hi Guys,
It's perhaps a silly question, but I prefer ask .
Is it possible to use Powershell with Starwind for Vsphere?
The main reason to do that is to avoid using a windows server.
Thanks !
Regards
Kader
Thu Apr 14, 2022 2:20 pm
Greetings,
Welcome to StarWind Forum and thanks for your question.
Yes. Please install the StarWindX module on any Windows10 PC or VM that has a connection to the VM.
kaderb
Fri Apr 15, 2022 1:11 pm
Thanks , Great news!
I want to use a free licence applied to the VSA Starwind for Vsphere (linux) and configure it with powershell.
You confirm again?
Mon Apr 18, 2022 7:53 am
Greetings,
Yes, it is doable. You need to install StarWind Management Console and Integrated Component Library to your Windows machine and run the script from there.
kaderb
Tue Apr 19, 2022 3:08 pm
Hi Guys !
I have tried to configure 3-nodes of VSAN for Vsphere by powershell with no success :(
I'm facing an
Invalid channel format [2]
The Iscsi ans the Sync connection are direct connected.
I have followed this technical paper : https://www.starwindsoftware.com/resour ... e-vsphere/
Here's my modified script :
param($addr="57.7.10.42", $port=3261, $user="root", $password="starwind",
	$addr2="57.7.10.43", $port2=$port, $user2=$user, $password2=$password,
	$addr3="57.7.10.44", $port3=$port, $user3=$user, $password3=$password,
	$fileName="New_disk",
	#$filePath="My computer\E\Starwind",
$filePath="VSA Storage\mnt",
	$numaNode=0,
#common
	$initMethod="Clear",
	$size=1000,
	$sectorSize=512,
	$failover=0,
#primary node
	$imagePath=$filePath,
    $imageName=$fileName,
	$createImage=$false,
	$targetAlias="starwind-esx-4",
	$autoSynch=$true,
	$poolName="",
	$syncSessionCount=1,
	$aluaOptimized=$true,
	$cacheMode="none",
	$cacheSize="",
	$syncInterface="#p2=172.16.21.20,p3=172.16.23.20 ",
	$hbInterface="#p2=172.16.11.20:3260;#p3=172.16.13.30:3260 -f $addr2,$addr3",
#secondary node
	$imagePath2=$filePath,
    $imageName2=$fileName,
	$createImage2=$false,
	$targetAlias2="starwind-esx-5",
	$autoSynch2=$true,
	$poolName2="",
	$syncSessionCount2=1,
	$aluaOptimized2=$true,
	$cacheMode2=$cacheMode,
	$cacheSize2=$cacheSize,
	$syncInterface2="#p1=172.16.21.10:3260;#p3=172.16.22.30:3260 ",
	$hbInterface2="#p1=172.16.11.10:3260;#p3=172.16.12.30:3260 -f $addr1,$addr3",
#third node
	$imagePath3=$filePath,
    $imageName3=$fileName,
	$createImage3=$false,
	$targetAlias3="starwind-esx-6",
	$autoSynch3=$true,
	$poolName3="",
	$syncSessionCount3=1,
	$aluaOptimized3=$true,
	$cacheMode3=$cacheMode,
	$cacheSize3=$cacheSize,
	$syncInterface3="#p1=172.16.22.10:3260;#p2=172.16.23.20:3260 ",
	$hbInterface3="#p1=172.16.12.10:3260;#p2=172.16.12.20:3260 -f $addr1;$addr2"
Import-Module StarWindX
try
	Enable-SWXLog
	$firstNode = new-Object Node
	$firstNode.HostName = $addr
	$firstNode.Size = $size
	$secondNode = new-Object Node
	$secondNode.HostName = $addr2
	$secondNode.HostPort = $port2
	$secondNode.Login = $user2
	$thirdNode = new-Object Node
	$thirdNode.HostName = $addr3
	$thirdNode.HostPort = $port3
	$thirdNode.Login = $user3
	$thirdNode.Password = $password3
	$thirdNode.ImagePath = $imagePath3
	$thirdNode.ImageName = $imageName3
	$thirdNode.CreateImage = $createImage3
	$thirdNode.TargetAlias = $targetAlias3
	$thirdNode.AutoSynch = $autoSynch3
	$thirdNode.SyncInterface = $syncInterface3
	$thirdNode.HBInterface = $hbInterface3
	$thirdNode.SyncSessionCount = $syncSessionCount3
	$thirdNode.ALUAOptimized = $aluaOptimized3
	$thirdNode.CacheMode = $cacheMode3
	$thirdNode.CacheSize = $cacheSize3
	$thirdNode.FailoverStrategy = $failover
	$server.Connect()
     #create image file
	New-ImageFile -server $server -path $filePath -fileName $fileName -size $size
	#create device
	$device = Add-ImageDevice -server $server -path $filePath -fileName $fileName -sectorSize $sectorSize -NumaNode $numaNode -CacheMode $cacheMode -CacheSize $cacheSize -header "test"
	$device
	#create target
	$target = New-Target -server $server -alias $targetAlias -devices $device.Name
	$target
catch
	Write-Host $_ -foreground red
finally
	$server.Disconnect()
try
	Enable-SWXLog
    $server2 = New-SWServer -host $addr2 -port $port -user $user -password $password
    echo "Serveur 2"
	$server2.Connect()
     #create image file
	New-ImageFile -server $server2 -path $filePath -fileName $fileName -size $size
	#create device
	$device = Add-ImageDevice -server $server2 -path $filePath -fileName $fileName -sectorSize $sectorSize -NumaNode $numaNode -CacheMode $cacheMode -CacheSize $cacheSize -header "test"
	$device
	#create target
	$target = New-Target -server $server2 -alias $targetAlias2 -devices $device.Name
	$target
catch
finally
	$server2.Disconnect()
try
	Enable-SWXLog
    $server3 = New-SWServer -host $addr3 -port $port -user $user -password $password
	$server3.Connect()
     #create image file
	New-ImageFile -server $server3 -path $filePath -fileName $fileName -size $size
	#create device
	$device = Add-ImageDevice -server $server3 -path $filePath -fileName $fileName -sectorSize $sectorSize -NumaNode $numaNode -CacheMode $cacheMode -CacheSize $cacheSize -header "test"
	$device
	#create target
	$target = New-Target -server $server3 -alias $targetAlias3 -devices $device.Name
	$target
catch
finally
	$server3.Disconnect()
try
	$device = Add-HADevice -server $server -firstNode $firstNode -secondNode $secondNode    -thirdNode $thirdNode   -initMethod $initMethod
	$syncState = $device.GetPropertyValue("ha_synch_status")
	while ($syncState -ne "1")
		# Refresh device info
		$device.Refresh()
		Start-Sleep -m 2000
catch
finally
Tue Apr 19, 2022 7:02 pm
The way you specify the channels is not valid. Please refer to this thread for more details https://forums.starwindsoftware.com/vie ... p+3#p31505.
kaderb
Mon Apr 25, 2022 2:22 pm
I have tried to change the script , the error have disappeared but no sync at all.
    $addr_iscsi_1_11="172.16.11.10",
    $addr_iscsi_1_13="172.16.13.10",
    $addr_sync_1_21="172.16.21.10",
    $addr_sync_1_23="172.16.23.10",
    $addr_iscsi_2_11="172.16.11.20",
    $addr_iscsi_2_12="172.16.12.20",
    $addr_sync_2_21="172.16.21.20",
    $addr_sync_2_22="172.16.22.20",
    $addr_iscsi_3_12="172.16.12.30",
    $addr_iscsi_3_13="172.16.13.30",
    $addr_sync_3_22="172.16.22.30",
    $addr_sync_3_23="172.16.23.30",
	$fileName="New_disk232",
#	$filePath="My computer\E\Starwind",
	$numaNode=0,
#common
	$size=1000,
	$sectorSize=512,
	$failover=0,
#primary node
	#$imagePath="VSA Storage\mnt",
	$imageName="masterImg3131",
	$createImage=$true,
	$targetAlias="targetha31",
	$autoSynch=$true,
	$poolName="pool1",
	$cacheMode="none",
	$cacheSize=128,
	$syncInterface=$("#p2={0}:3260;#p3={1}:3260" -f $addr_sync_2_21,$addr_sync_3_23),
	$hbInterface=$("#p2={0}:3260;#p3={1}:3260" -f $addr_iscsi_2_11,$addr_iscsi_3_13),
    $createTarget=$true,
#secondary node
	#$imagePath2="VSA Storage\mnt",
	$imageName2="partnerImg323",
	$createImage2=$true,
	$targetAlias2="partnerha32",
	$autoSynch2=$true,
	$poolName2="pool1",
	$aluaOptimized2=$false,
	$syncInterface2=$("#p1={0}:3260;#p3={1}:3260" -f $addr_sync_1_21,$addr_sync_3_22),
	$hbInterface2=$("#p1={0}:3260;#p3={1}:3260" -f $addr_iscsi_1_11,$addr_iscsi_3_12),
    $createTarget2=$true,
#third node
	#$imagePath3="VSA Storage\mnt",
	$imageName3="partnerImg333",
	$createImage3=$true,
	$targetAlias3="partnerha33",
	$autoSynch3=$true,
	$poolName3="pool1",
	$aluaOptimized3=$false,
	$syncInterface3=$("#p1={0}:3260;#p2={1}:3260" -f $addr_sync_1_23,$addr_sync_2_22),
	$hbInterface3=$("#p1={0}:3260;#p2={1}:3260" -f $addr_iscsi_1_13,$addr_iscsi_2_12),
    $createTarget3=$true
try
	Enable-SWXLog
	$server.Connect()
    $thirdNode.CreateTarget = $createTarget3
	$server.Connect()
     #create image file
	#create device
	$device
	#create target
    #echo $target = New-Target -server $server -alias $targetAlias -devices $device.Name
	$target
catch
finally
try
	Enable-SWXLog
    echo "Serveur 2"
	$server2.Connect()
     #create image file
	#create device
	#create target
catch
finally
try
	Enable-SWXLog
	$server3.Connect()
     #create image file
	#create device
	$device
	#create target
	#$target
catch
finally
    #echo  $device = Add-HADevice -server $server -firstNode $firstNode -secondNode $secondNode -thirdNode $thirdNode -initMethod $initMethod
		$device.Refresh()
		Start-Sleep -m 2000
catch
finally
Mon Apr 25, 2022 2:52 pm
Please make sure to add the correct interfaces. It might appear that you are typing the "local" IP addresses where the script implies the partner IP addresses to be listed.
kaderb
Mon Apr 25, 2022 3:12 pm
Hi Yaroslav,
Thanks for this quick answer.
My 3 servers are directly connected for sync ans iscsi ports and for each server .
FOr each server, i have put for Sync and HB is partner.
Perharps my syntax is not good?
For instance, the first node :
I want that the result of $syncInterface are : "172.16.21.20","172.16.23.30" and for $hbInterface : 172.16.11.20 , 172.16.13.30
Is that correct?
Regards
Kader
Tue Apr 26, 2022 1:22 pm
Greetings,
There is indeed a problem with syntax.
Please fill in the gaps of the script and make sure to type PARTNER IP addresses, not LOCAL ones.
kaderb
Mon May 16, 2022 12:34 pm
Thanks for your answer.
All is configured.
Anyway the devices still not synchronized and I don't understand why.
When I try using the script SyncHaDevice.ps1 to launche a sync, this error is returned :
PS C:\WINDOWS\system32> C:\Program Files\StarWind Software\StarWind\StarWindX\Samples\powershell\SyncHaDevice.ps1
Synchronize device HAImage1
Failed to perform synchronization (1) from
control 0x00000000000F7A00 -Synchronize: -SynchronizationType:"1"
200 Failed: can't find available or valid partner for synchronization..
Here's the detail of a HaDevice of the Target :
DeviceType              : HA Image
DeviceId                : 0x00000000000F7A00
File                    : VSA Storage\mnt\disk1\masterImg31_HA.swdsk
TargetName              : iqn.2008-08.com.starwindsoftware:57.7.10.42-targetha31
TargetId                : 0x00000000000F9600
CacheMode               : none
CacheSize               : 0
CacheBlockExpiryPeriod  : 0
Exists                  : True
DeviceLUN               : 0
IsSnapshotsSupported    : False
Snapshots               :
SectorSize              : 512
State                   : 0
Parent                  :
Partners                : System.__ComObject
SynchronizationChannels :
HeartbeatChannels       :
SyncStatus              : 3
SyncPercent             : 0
IsWaitingAutosync       : False
SyncTrafficShare        : 50
NodeType                : 1
FailoverStrategy        : 0
MaintenanceMode         : 0
Mon May 16, 2022 12:50 pm
Could you kindly tell me if the initial synchronization was ever completed? Please also show the script that you used.
kaderb
Mon May 16, 2022 2:15 pm
Hi Yaroslav,
The intial sync was never been comleted, loop in 0%
Here's the script :
#common
	$size=12,
	$sectorSize=512,
	$failover=0,
#primary node
	$imagePath="VSA Storage\mnt\disk1",
	$imageName="masterImg31",
	$createImage=$true,
	$autoSynch=$true,
	$poolName="pool1",
	$cacheMode="",
	$cacheSize="",
	$syncInterface=$("#p2=172.16.21.20:3260;#p3=172.16.23.30:3260" -f $addr2;$addr3 ),
	$hbInterface=$("#p2=172.16.11.20:3260;#p3=172.16.13.30:3260"-f $addr2;$addr3),
#secondary node
	$imagePath2="VSA Storage\mnt\disk1",
	$imageName2="partnerImg32",
	$autoSynch2=$true,
	$poolName2="pool1",
	$syncInterface2=$("#p1=172.16.21.10:3260;#p3=172.16.22.30:3260" -f $addr;$addr3 ),
	$hbInterface2=$("#p1=172.16.11.10:3260;#p3=172.16.12.30:3260" -f $addr;$addr3 ),
#third node
	$imagePath3="VSA Storage\mnt\disk1",
	$imageName3="partnerImg33",
	$autoSynch3=$true,
	$poolName3="pool1",
	$syncInterface3=$("#p1=172.16.23.10:3260;#p2=172.16.22.20:3260" -f $addr;$addr2),
	$hbInterface3=$("#p1=172.16.13.10:3260;#p2=172.16.12.20:3260" -f $addr;$addr2)
try
	Enable-SWXLog
	$server.Connect()
		$device.Refresh()
		Start-Sleep -m 2000
catch
finally
Tue May 17, 2022 5:07 pm
Please contact us at support@starwind.com using this thread and 695379 as your references.
