error creating 2 node HA with free vsan
yosiyakovi
Fri Mar 31, 2023 6:51 am
when i am trying to create 2 node vsan using the CreateHA_2.ps1 PowerShell script i am getting error message:
"control HAImage -GetDefaults:"" -deviceSectorSizeBytes:"512"
101 Failed: operation cannot be completed..
i have configured "$sectorSize=512" but without any success
Fri Mar 31, 2023 7:18 am
Please make sure you are using the script right. See https://forums.starwindsoftware.com/vie ... p+3#p31505 for more details.
yosiyakovi
Fri Mar 31, 2023 10:14 am
I did follow the guide and searched the forum but no one have the error that i am having
the exact output is:
Request to 192.168.1.21 ( 192.168.1.21 ) : 3261
*** 192.168.1.21 is the main vsan appliance address
Fri Mar 31, 2023 12:00 pm
Can you please provide the script and the IP addresses?
yosiyakovi
Fri Mar 31, 2023 2:44 pm
Node1:
Management 192.168.1.21
Sync 192.168.4.21
HB 192.168.5.21
Node2:
Management 192.168.1.22
Sync 192.168.4.22
HB 192.168.5.22
Script:
param($addr="192.168.1.21", $port=3261, $user="root", $password="starwind",
$addr2="192.168.1.22", $port2=$port, $user2=$user, $password2=$password,
#common
$initMethod="Clear",
$size=12,
$sectorSize=512,
$failover=0,
$bmpType=1,
$bmpStrategy=0,
#primary node
$imagePath="\mnt\DISK01",
$imageName="masterImg23",
$createImage=$true,
$storageName="",
$targetAlias="targetha23",
$autoSynch=$true,
$poolName="pool1",
$syncSessionCount=1,
$aluaOptimized=$true,
$cacheMode="wb",
$cacheSize=128,
$syncInterface="#p2=192.168.4.22:3260" -f $addr2,
$hbInterface="#p2=192.168.5.22:3260",
$createTarget=$true,
$bmpFolderPath="",
#secondary node
$imagePath2="\mnt\DISK01",
$imageName2="partnerImg24",
$createImage2=$true,
$storageName2="",
$targetAlias2="partnerha24",
$autoSynch2=$true,
$poolName2="pool1",
$syncSessionCount2=1,
$aluaOptimized2=$false,
$cacheMode2=$cacheMode,
$cacheSize2=$cacheSize,
$syncInterface2="#p1=192.168.4.21:3260" -f $addr,
$hbInterface2="#p1=192.168.5.21:3260",
$createTarget2=$true,
$bmpFolderPath2=""
Import-Module StarWindX
try
$server.Connect()
$firstNode = new-Object Node
$firstNode.HostName = $addr
$firstNode.HostPort = $port
$firstNode.Login = $user
$firstNode.Size = $size
#$firstNode.SectorSize = $sectorSize
$secondNode = new-Object Node
$secondNode.HostName = $addr2
$secondNode.HostPort = $port2
$secondNode.Login = $user2
Start-Sleep -m 2000
$device.Refresh()
catch
Write-Host $_ -foreground red
finally
$server.Disconnect()
Sat Apr 01, 2023 3:50 am
I can see the script underwent some customizations. Please try commenting the bmpType fields.
yosiyakovi
Sat Apr 01, 2023 5:29 am
I commented the bmp fields but still getting the same error
The error is only when i am trying to make HA,
when i just creating single image from PowerShell its working on both nodes.
Sat Apr 01, 2023 5:51 am
Can you please take the script "as is" and fill in the gaps?
Please use the script I shared above as a reference.
yosiyakovi
Sat Apr 01, 2023 12:24 pm
did that but i am getting the same error
yosiyakovi
Sat Apr 01, 2023 5:06 pm
I even installed the VSAN from scratch and still got the same error message
When i search the logs i am getting those messages:
4/1 13:06:07.351799 30 conf: TelnetListener::listenConnections: Accepted control connection from 192.168.1.1:53748.
4/1 13:06:07.371932 38 FileBrowser: *** CFileBrowser::parsePath: Could not create image : provided path has invalid extension!
4/1 13:06:07.371971 38 Srv: *** iScsiServer::list: Error parsing path: VSA Storage\mnt\
4/1 13:06:17.256773 38 FileBrowser: *** CFileBrowser::parsePath: Could not create image : provided path has invalid extension!
4/1 13:06:17.256803 38 Srv: *** iScsiServer::list: Error parsing path: VSA Storage\mnt\
4/1 13:06:17.269822 38 conf: ControlConnection::processConnection: Control connection closed.
Sun Apr 02, 2023 11:23 am
It points to the path issues. Please share the script with me once again.
yosiyakovi
Sun Apr 02, 2023 7:40 pm
Here is the script:
#common
$size=1200,
$sectorSize=512,
$failover=0,
#primary node
$imagePath="VSA Storage\mnt\DISK01",
$imageName="masterImg21",
$createImage=$true,
$storageName="",
$targetAlias="targetha21",
$autoSynch=$true,
$poolName="pool1",
$cacheMode="wb",
$cacheSize=128,
$hbInterface="#p2=192.168.5.22:3260,192.168.1.22:3260" -f $addr2,
#secondary node
$imagePath2="VSA Storage\mnt\DISK01",
$imageName2="partnerImg22",
$storageName2="",
$targetAlias2="partnerha22",
$autoSynch2=$true,
$poolName2="pool1",
$aluaOptimized2=$true,
$hbInterface2="#p1=192.168.5.21:3260,192.168.1.21:3260" -f $addr,
try
$server.Connect()
#$firstNode.BitmapStoreType = $bmpType
#$firstNode.BitmapStrategy = $bmpStrategy
#$firstNode.BitmapFolderPath = $bmpFolderPath
#$secondNode.BitmapFolderPath = $bmpFolderPath2
Start-Sleep -m 2000
$device.Refresh()
catch
finally
Mon Apr 03, 2023 3:17 pm
Please try the path without VSA Storage, try using \mnt\disk01.
yosiyakovi
Tue Apr 04, 2023 3:50 am
I found post in the forum and followed the script
https://forums.starwindsoftware.com/vie ... %5C#p33441
now i am getting other error
"Mandatory parameters are missed"
here is my updated script
Import-Module StarwindX
try {
# Enable-SWXLog
$vsa1 = New-SWServer -host 192.168.1.21 -port 3261 -user root -password starwind
$vsa2 = New-SWServer -host 192.168.1.22 -port 3261 -user root -password starwind
$vsa1.Connect()
$vsa2.Connect()
#create image file
Write-Host "Creating Image on vsa1"
New-ImageFile -server $vsa1 -path "VSA Storage\mnt\DISK01" -fileName "TestLUN00" -size 500
Write-Host "Creating image on vsa2"
New-ImageFile -server $vsa2 -path "VSA Storage\mnt\DISK01" -fileName "TestLUN00" -size 500
$firstNode.HostName = "192.168.1.21"
$firstNode.ImagePath = "VSA Storage\mnt\DISK01"
$firstNode.ImageName = "TestLUN00"
$firstNode.Size = 500
$firstNode.CreateImage = $false
$firstNode.TargetAlias = "TestLUN00"
$firstNode.AutoSynch = $true
$firstNode.SyncInterface = "#p2=192.168.4.22:3260"
$firstNode.HBInterface = "#p2=192.168.5.22:3260"
$firstNode.PoolName = "pool1"
$firstNode.createTarget=$true
$firstNode.SectorSize = 512
$secondNode.HostName = "192.168.1.22"
$secondNode.HostPort = "3261"
$secondNode.Login = "root"
$secondNode.ImagePath = "VSA Storage\mnt\DISK01"
$secondNode.ImageName = "TestLUN00"
$secondNode.Size = 500
$secondNode.CreateImage = $false
$secondNode.TargetAlias = "TestLUN00"
$secondNode.AutoSynch = $true
$secondNode.SyncInterface = "#p1=192.168.4.21:3260"
$secondNode.HBInterface = "#p1=192.168.5.21:3260"
$secondNode.PoolName = "pool1"
$secondNode.createTarget=$true
$secondNode.SectorSize = 512
Write-Host "Creating HA"
$device = Add-HADevice -server $vsa1 -firstNode $firstNode -secondNode $secondNode -initMethod "Clear"
Start-Sleep -m 2000
$device.Refresh()
catch
finally
$vsa1.Disconnect()
$vsa2.Disconnect()
Tue Apr 04, 2023 9:53 pm
Greetings. Thank you for your update and effort. We are looking into the service's functioning. As a workaround, you could downgrade to 13586.
OVF template: https://starwind.my.salesforce.com/sfc/ ... 8yWr3lc4g8
Downgrade link: https://starwind.my.salesforce.com/sfc/ ... i24Wi_HCeA (downgrading is the same as updating https://knowledgebase.starwindsoftware. ... d-version/)
Management console: https://starwind.my.salesforce.com/sfc/ ... mnnA8xtFI4
