VSAN free 3 node Setup issue
joerg
Fri Dec 08, 2023 2:25 pm
Hi there,
back after appr. 7 years :-)
I am stuck in the setup of a 3-way-HA cluster.
I started with 3 VMs (HyperV) with 8 cores, and 3 NICs based on this drive: sw-vsa-hyper-v-build-15020.vhdx.
The 3 machines are up and running, the NICs are configured
10.0.10.18x MGMT
10.0.50.18x iSCSI
10.0.56.18x SYNC
x{1,2,3}
On every VM I created
- a RAID device
- a VDO device
Which is mounted on /mnt
I installed the Powershell package on a Server 2019 machine and adapted the creatHA_3.ps1
param($addr="10.0.10.181", $port=3261, $user="root", $password="starwind",
	$addr2="10.0.10.182", $port2=$port, $user2=$user, $password2=$password,
	$addr3="10.0.10.183", $port3=$port, $user3=$user, $password3=$password,
#common
	$initMethod="SyncFromFirst",
	$size=1000,
	$sectorSize=512,
	$failover=0,
	#$bmpType=1,
	#$bmpStrategy=0,
#primary node
	$imagePath="VSA Storage\mnt",
	$imageName="masterImg31",
	$createImage=$true,
	$targetAlias="targetha31",
	$autoSynch=$true,
	$poolName="Pool1",
	$storageName="",
	$syncSessionCount=1,
	$aluaOptimized=$true,
	$cacheMode="wb",
	$cacheSize=128,
	$syncInterface="#p2=10.0.56.182:3260;#p3=10.0.56.183:3260",
	$hbInterface="#p2=10.0.10.182:3260,10.0.50.182:3260;#p3=10.0.10.183:3260,10.0.50.183:3260",
	#$bmpFolderPath="",
#secondary node
	$imagePath2="VSA Storage\mnt",
	$imageName2="partnerImg32",
	$createImage2=$true,
	$targetAlias2="partnerha32",
	$autoSynch2=$true,
	$poolName2="Pool1",
	$storageName2="",
	$syncSessionCount2=1,
	$aluaOptimized2=$false,
	$cacheMode2=$cacheMode,
	$cacheSize2=$cacheSize,
	$syncInterface2="#p1=10.0.56.181:3260;#p3=10.0.56.183:3260",
	$hbInterface2="#p1=10.0.10.181:3260,10.0.50.181:3260;#p3=10.0.10.183:3260,10.0.50.183:3260",
	#$bmpFolderPath2="",
#third node
	$imagePath3="VSA Storage\mnt",
	$imageName3="partnerImg33",
	$createImage3=$true,
	$targetAlias3="partnerha33",
	$autoSynch3=$true,
	$poolName3="Pool1",
	$storageName3="",
	$syncSessionCount3=1,
	$aluaOptimized3=$false,
	$cacheMode3=$cacheMode,
	$cacheSize3=$cacheSize,
	$syncInterface3="#p1=10.0.56.181:3260;#p2=10.0.56.182:3260",
	$hbInterface3="#p1=10.0.10.181:3260,10.0.50.181:3260;#p2=10.0.10.182:3260,10.0.50.182:3260"
	#$bmpFolderPath3=""
Import-Module StarWindX
try
	Enable-SWXLog
	$server.Connect()
	$firstNode = new-Object Node
	$firstNode.HostName = $addr
	$firstNode.HostPort = $port
	$firstNode.Size = $size
	#$firstNode.BitmapStoreType = $bmpType
	#$firstNode.BitmapStrategy = $bmpStrategy
	#$firstNode.BitmapFolderPath = $bmpFolderPath
	$secondNode = new-Object Node
	$secondNode.HostName = $addr2
	$secondNode.HostPort = $port2
	$secondNode.Login = $user2
	#$secondNode.BitmapFolderPath = $bmpFolderPath2
	$thirdNode = new-Object Node
	$thirdNode.HostName = $addr3
	$thirdNode.HostPort = $port3
	$thirdNode.Login = $user3
	$thirdNode.Password = $password3
	$thirdNode.ImagePath = $imagePath3
	$thirdNode.ImageName = $imageName3
	$thirdNode.CreateImage = $createImage3
	$thirdNode.TargetAlias = $targetAlias3
	$thirdNode.AutoSynch = $autoSynch3
	$thirdNode.SyncInterface = $syncInterface3
	$thirdNode.HBInterface = $hbInterface3
	$thirdNode.SyncSessionCount = $syncSessionCount3
	$thirdNode.ALUAOptimized = $aluaOptimized3
	$thirdNode.CacheMode = $cacheMode3
	$thirdNode.CacheSize = $cacheSize3
	$thirdNode.FailoverStrategy = $failover
	#$thirdNode.BitmapFolderPath = $bmpFolderPath3
	$device = Add-HADevice -server $server -firstNode $firstNode -secondNode $secondNode -thirdNode $thirdNode -initMethod $initMethod
	$syncState = $device.GetPropertyValue("ha_synch_status")
    write-host "Start Sync..."
	while ($syncState -ne "1")
		# Refresh device info
		$device.Refresh()
		Start-Sleep -m 2000
catch
	Write-Host $_ -foreground red
finally
	$server.Disconnect()
The script runs, but do not create imagefiles on nodes 2 and 3, only on node 1. Therefore no sync takes place.
Message after completion only:
Request to 10.0.10.181 ( 10.0.10.181 ) : 3261
Any ideas, what could be wrong with my script or my setup?
Thx in adcance, cheers,
Jörg
PS.: with the TRIAL version of vsan and the same setup of VMs (differnt VHDX of course, but same NICs, Procs, RAM) everything is fine.
Fri Dec 08, 2023 3:07 pm
Welcome back!! :) directory should point to your device: e.g. /mnt/disk not just /mnt :)
If that does not work, try commenting out the areas mentioning bitmap.
Hope that is the key.
I'd also suggest not using VDO with latest builds in prod (trim/unmap can cause hiccups, we should fix it soon in CVM).
joerg
Fri Dec 08, 2023 5:24 pm
Hi Yaroslav,
many thanks for quick reply.
I am a step further but run into next "problem": I have to investigate over the weekend.
control HAImage -CreateHeader:"" -DeviceHeaderPath:"VSA Storage\mnt\SS01_P1\masterImg31_HA.swdsk" -Type:"ImageFile_HA" -file:"imagefile2" -size:"1000" -Priority:"#p0=0;#p1=1;#p2=2" -nodeType:"#p0=1;#p1=1;#p2=1" -PartnerTargetName:"#p1=iqn.2008-08.com.starwindsoftware:10.0.10.182-partnerha32;#p2=iqn.2008-08.com.starwindsoftware:10.0.10.183-partnerha33" -PartnerIP:"#p1=10.0.56.182:sync:3260:1,10.0.10.182:heartbeat:3260:1,10.0.50.182:heartbeat:3260:1;#p2=10.0.56.183:sync:3260:1,10.0.10.183:heartbeat:3260:1,10.0.50.183:heartbeat:3260:1" -IsAutoSynchEnabled:"1" -AuthChapLogin:"#p1=0b;#p2=0b" -AuthChapPassword:"#p1=0b;#p2=0b" -AuthMChapName:"#p1=0b;#p2=0b" -AuthMChapSecret:"#p1=0b;#p2=0b" -AuthChapType:"#p1=none;#p2=none" -Offset:"0" -CacheMode:"wb" -CacheSizeMB:"128" -serial:"C91FD58A9FD3B77E" -eui64:"C91FD58A9FD3B77E" -revision:"0001" -product:"STARWIND" -vendor:"STARWIND" -Replicator:"#p0=0" -WitnessType:"0" -AluaAccessState:"#p0=0;#p1=1;#p2=1"
200 Failed: invalid partner info..
I think, I saw this message in some other forum posts... will search for them first.
Cheers,
Jörg
Fri Dec 08, 2023 6:01 pm
Hi Jörg,
Can you please make sure there are no duplicate files in that directory?
joerg
Fri Dec 08, 2023 6:24 pm
the dirs (mount points) are all empty.
do I have to mount on all VMs to the same dir?
on the VMs I have now
\mnt\SS01_P1
\mnt\SS02_P1
\mnt\SS03_P1
this is configured in the parameter
$imagePath="VSA Storage\mnt\SS01_P1",
$imagePath2="VSA Storage\mnt\SS02_P1",
$imagePath3="VSA Storage\mnt\SS03_P1",
Sat Dec 09, 2023 6:35 am
Greetings,
They are ok to be in different directories.
Can you make sure that imagefile inside the directory is carrying a different name (i.e., no target and imagefile names are conflicting with the existing deployments)?
joerg
Tue Dec 12, 2023 8:03 pm
I gave up...
three days of intensive testing with "all possible" settings. :-(
For checking the infrastructure I set up 2 node clusters, with server 1 and 2 and server 1 and 3. All good.
Today I tried to add a HA-Member to the 2 node cluster with the script AddHaPartner.ps1, but failed.
So I stay at the moment with the 2 node cluster as this should fit my needs... will see.
Cheers,
Jörg
Tue Dec 12, 2023 10:03 pm
Jörg,
You can repurpose the system into GRID (see more at https://www.starwindsoftware.com/grid-architecture-page).
You can also reach out to support@starwind.com using this thread as a reference and 1076002.
