Azure to ESXi fail
ghostman65
Thu Feb 22, 2024 1:25 am
Go through app screens without incident, but hit finish and get the following on gui and I notice that the disk in Azure is still has disk in export mode.
Error opening image
Response is incorrect
Conversion failed
and the following in the log
The log file name: 'logs\V2V_Log-20240221-201448.log' (PID 10000)
2/21 20:14:48.224 1480 Facility ???INFO: CV2V_ConverterApp::InitInstance: SetDllDirectory: C:\Program Files\StarWind Software\StarWind V2V Converter\lib
2/21 20:14:48.224 1480 Facility ???INFO: CV2V_ConverterApp::InitInstance: File Version: 9.0.1.413
2/21 20:14:48.234 1480 Facility ???INFO: CV2V_ConverterApp::InitInstance: Load language IDR_XML_ENGLISH
2/21 20:14:48.234 1480 Facility ???INFO: CV2V_ConverterApp::InitInstance: Set current language English
2/21 20:14:48.244 1480 Facility ???INFO: CPS_V2V_Converter::CPS_V2V_Converter: Version MajorVersion 10, MinorVersion 0, BuildNumber 19045
2/21 20:14:48.244 1480 Facility ???INFO: WrapperHyperV::WrapperHyperV: LoadLibrary C:\Windows\system32\wbem\wmiutils.dll - 3ec40000
2/21 20:14:48.253 1480 Facility ???INFO: WrapperHyperV::WrapperHyperV: LoadLibrary C:\Windows\system32\wbem\wmiutils.dll - 3ec40000
2/21 20:14:56.144 1480 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eSynchronization
2/21 20:18:13.325 13c4 Facility ???INFO: VMConverter::AzureConverter::ThreadProc: Start token control expires
2/21 20:18:16.816 1480 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eInputVM
2/21 20:18:24.035 1480 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eLocationTo
2/21 20:18:27.238 1480 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eVMSettingsAWS
2/21 20:18:51.159 1480 Facility ???INFO: WrapperESXI::connect: m_url - https://10.4.3.23/sdk
2/21 20:18:51.253 1480 Facility ???INFO: WrapperESXI::connect: fullName - Administrator vsphere.local, key - 528996ba-9d4e-9623-6ac2-5949ecd4f78b
2/21 20:18:51.253 1480 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eESXConnectionTo
2/21 20:18:51.800 1480 Facility ???INFO: VMConverter::ESXIConverter::GetHostListInfo: ESX version: 8.0.2
2/21 20:18:56.003 1480 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eOptionsESXI
2/21 20:19:01.465 1480 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eTypeP2V
2/21 20:19:10.097 1480 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eHYPERVConnectionTo
2/21 20:19:10.113 1ce4 Facility ???INFO: CPPConverting::Convert: InConvertType: 9, OutConvertType: 5
2/21 20:19:10.113 1ce4 Facility ???INFO: CPPConverting::ConvertDisks: pathInput: /subscriptions/d771237e-004c-455f-b62f-76a2545b8786/resourceGroups/Nakivo_group/providers/Microsoft.Compute/disks/nakivo_datadisk_1, pathOutput: [DTFA-repo] nakivo_datadisk_1.vmdk
2/21 20:19:10.787 1ce4 Facility ???ERROR: AzureDisk::CreateInputImage: Size disk is - 303
2/21 20:19:10.787 1ce4 Facility ???INFO: CPPConverting::ConvertDisks: CreateInputImage: 2
2/21 20:19:10.803 1ce4 Facility ???ERROR: CPPConverting::Convert: FAILED
Fri Feb 23, 2024 12:24 am
Welcome to StarWind Forum. We will have a closer look at the logs.
ghostman65
Fri Feb 23, 2024 4:30 am
FYI, disk is 4.5TB.
Fri Feb 23, 2024 8:16 am
Thanks for adding more details.
Fri Mar 01, 2024 5:22 pm
We need slightly more time to look into the logs and model the systems. I will keep you posted.
Tue Mar 05, 2024 10:12 pm
Thank you for your patience.
My colleagues noticed that the original disk is 4K VHDX. It cannot be recognized by VMware, therefore conversion fails. If the VM is running Windows, try converting its individual disks as VMDK.
