Cant connect to ESXi/Vcenter with V2V Migrator
aroc870
Thu Aug 15, 2024 6:37 pm
Greetings,
I'm having an auth issue that I cannot seem to resolve. I'm attempting to convert VMWare VM's to HyperV. The issue is I am unable to authentication to the ESXi server. I keep getting the message the username and password is incorrect even though I'm SURE I'm entering in the proper credentials....just says "Cannot complete login due to an incorrect username or password". I can login to the console just fine with the same account.
I'm using the latest V2V converter (9.0.1.509) and vSphere(7.0.3.001000). Am I missing something? Any services need to be running to auth? What could be preventing authentication. Any guidance is greatly appreciated. Thanks!
Mon Aug 19, 2024 1:09 pm
Sorry for the delay.
What ESXi version it is?
Try disabling firewall and use root credentials.
aroc870
Thu Aug 22, 2024 5:07 pm
Thanks for the response. I tried disabling the firewall but no luck.
Version is (ESXi version 7.0.3)
Thu Aug 22, 2024 5:24 pm
Please try using ESXi root password.
Could you run V2V from the VM that is running in the same network as ESXi host?
