P2V error file not found
m_off
Wed Sep 25, 2024 5:46 pm
I am attempting to do a P2V conversion of a Win Server 2019 to VMware vCenter 8.0.3
When it starts its process it says it is taking snapshots then it reports
" Creating image file
Error creating image
A file was not found
Conversion failed"
What should I look into that might be the issue?
Wed Sep 25, 2024 10:23 pm
Please make sure the firewall ports are open, there is enough space on the destination, and the source file systems are OK.
As a workaround, you can try disk2vhd conversion and convert that file into VMDK as the local file.
m_off
Thu Sep 26, 2024 10:07 am
What firewall ports need to be open?
There is plenty of disk space on my vCenter datastore. The VM is being created along with a datastore folder for it.
The system for the physical machine is not reporting any file errors and is running fine.
I have two disks on the physical machine so how could I do the disk2vhd workaround and get both as part of the new VM? That is why I am trying to do the entire machine.
Thu Sep 26, 2024 11:31 am
See the ports viewtopic.php?t=6794.
Convert disks one by one and recreate the VM.
Please also share the full conversion log with me (normally they are under C:\Program Files\StarWind Software\StarWind V2V Converter\logs).
m_off
Thu Sep 26, 2024 12:07 pm
Here is the log file
The log file name: 'logs\V2V_Log-20240926-075059.log' (PID 6072)
9/26 7:50:59.310 1c34 Facility ???INFO: CV2V_ConverterApp::InitInstance: SetDllDirectory: C:\Program Files\StarWind Software\StarWind V2V Converter\lib
9/26 7:50:59.310 1c34 Facility ???INFO: CV2V_ConverterApp::InitInstance: File Version: 9.0.1.509
9/26 7:50:59.325 1c34 Facility ???INFO: CV2V_ConverterApp::InitInstance: Load language IDR_XML_ENGLISH
9/26 7:50:59.325 1c34 Facility ???INFO: CV2V_ConverterApp::InitInstance: Set current language English
9/26 7:50:59.325 1c34 Facility ???INFO: CPS_V2V_Converter::CPS_V2V_Converter: Version MajorVersion 10, MinorVersion 0, BuildNumber 17763
9/26 7:50:59.325 1c34 Facility ???INFO: WrapperHyperV::WrapperHyperV: LoadLibrary C:\Windows\system32\wbem\wmiutils.dll - 99a00000
9/26 7:51:22.405 1c34 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eAWSConnection
9/26 7:51:27.405 1c34 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eAzureConnectionTo
9/26 7:51:31.296 1c34 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eLocationTo
9/26 7:51:32.952 1c34 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eESXConnectionTo
9/26 7:51:49.671 1c34 Facility ???INFO: WrapperESXI::connect: m_url - https://192.168.5.16/sdk
9/26 7:51:49.718 1c34 Facility ???INFO: WrapperESXI::connect: fullName - Administrator vsphere.local, key - 522f232a-92fb-4386-baf5-3fdbc50e26ef
9/26 7:51:49.718 1c34 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eVMSettingsESX
9/26 7:51:49.749 1c34 Facility ???INFO: VMConverter::ESXIConverter::GetHostListInfo: ESX version: 8.0.3
9/26 7:52:56.815 1c34 Facility ???INFO: ICPPage::OnWizardNext: SetActivePage - eConverting
9/26 7:52:56.830 1ce8 Facility ???INFO: CPPConverting::Convert: InConvertType: 3, OutConvertType: 6
9/26 7:52:57.002 1ce8 Facility ???INFO: WrapperESXI::Wait: Progress - 5
9/26 7:52:57.002 1ce8 Facility ???INFO: WrapperESXI::Wait: Progress - 6
9/26 7:52:57.456 1ce8 Facility ???INFO: WrapperESXI::Wait: Progress - 10
9/26 7:52:57.456 1ce8 Facility ???INFO: WrapperESXI::Wait: Progress - 15
9/26 7:52:57.502 1ce8 Facility ???INFO: WrapperESXI::Wait: Progress - 25
9/26 7:52:57.581 1ce8 Facility ???INFO: WrapperESXI::Wait: Progress - 62
9/26 7:52:57.627 1ce8 Facility ???INFO: WrapperESXI::Wait: Progress - 99
9/26 7:52:57.862 1ce8 Facility ???INFO: VMConverter::ESXIConverter::CreateVM: createVM is true, vm-3013
9/26 7:52:57.862 1ce8 Facility ???INFO: CPPConverting::ConverterESX: Create VM vm-3013
9/26 7:52:57.940 1ce8 Facility ???INFO: CPPConverting::ConvertDisks: pathInput: 0, pathOutput: [Nederland-DS] 4f35f566-7c30-b5a7-983b-d404e623f710/RLTDC/HDD0.mvmdk
9/26 7:52:57.940 1ce8 Facility ???INFO: P2V::CreateInputImage: path 0
9/26 7:52:57.940 1ce8 Facility ???INFO: P2V::CreateInputImage: Size 0 - 249510756352, BytesPerSector - 512
9/26 7:53:10.753 1ce8 Facility ???INFO: CPPConverting::ConvertDisks: CreateInputImage: 0
9/26 7:53:10.784 1ce8 Facility ???INFO: ESXVmdk::ParseFile: sFilename - [Nederland-DS] 4f35f566-7c30-b5a7-983b-d404e623f710/RLTDC/HDD0.mvmdk
9/26 7:53:10.784 1ce8 Facility ???INFO: ESXVmdk::ParseFile: m_cvmxSpec - moref=vm-3013
9/26 7:53:10.784 1ce8 Facility ???INFO: ESXVmdk::ParseFile: sslThumbprint - AB:9F:E4:D1:A9:9C:FF:D9:C5:67:AA:7D:F3:79:39:43:9B:E4:BC:98
9/26 7:53:11.019 1ce8 Facility ???ERROR: ESXVmdk::ParseFile: m_VixDiskLib_Open is fail - 4, A file was not found
9/26 7:53:11.019 1ce8 Facility ???ERROR: ESXIDisk::CreateOutputImage: ParseFile is fail
9/26 7:53:11.019 1ce8 Facility ???INFO: CPPConverting::ConvertDisks: CreateOutputImage: 1
9/26 7:53:11.019 1ce8 Facility ???ERROR: CPPConverting::Convert: FAILED
9/26 7:53:30.269 1b08 Facility ???INFO: VMConverter::ESXIConverter::Connection::<lambda_8874940e4602bbfc5e7b4b277e23eb86>::operator (): No_timeout ESX connection
Thu Sep 26, 2024 5:07 pm
Could you please try converting an individual disk, or its partition to disk2vhd? And then try converting the local device to the ESXi.
Please also confirm the firewall is allowing the conversion.
