Cluster down
atwell.greenaway
Mon Sep 30, 2024 6:33 pm
Error: current node is not synchronized
Mon Sep 30, 2024 8:53 pm
Make sure to follow this guide https://knowledgebase.starwindsoftware. ... -blackout/.
Use scripts to manually mark nodes as synchronized.
P.S. If you have a write-back cache, remove it as described here https://knowledgebase.starwindsoftware. ... -l1-cache/
atwell.greenaway
Mon Sep 30, 2024 9:17 pm
No option available to synchronize as the free version is being used.
atwell.greenaway
Mon Sep 30, 2024 9:19 pm
Do the drives get connected with Microsoft iSCSI Initiator or does the StarWind make the connection?
Mon Sep 30, 2024 9:40 pm
Please use SyncHADevice.ps1 from C:\Program Files\StarWind Software\StarWind\StarWindX\Samples\powershell.
There are also several threads like this one viewtopic.php?f=5&t=6194&p=37569&hilit= ... %3E#p37569 that describe the way out of this problem.
It is the initiator who comes to establish the connection if it is set up correctly.
If the devices are not synchronized on both nodes, the Initiator can't connect.
