Recover primary node only from maintance mode
ASAC
Mon Oct 28, 2024 1:27 pm
Hi guys;
I'm just evaluating Starwind VSAN and I'm right now working on different scenarios.
After a sucessfull two node HA build on VMWare EXSi, I set both nodes to maintance mode and shutdown both machines.
Then I started only the primary node (I want to simulate a total blackout of the secondary node). The primary node started in Maintenance mode.
I didn't found a way to enable only the first node. Anytime I tried to run the maintenance mode script I got an error like "connection with partner node is
invalid".
What's the correct procedure for this kind of scenario?
Thanks in advance!
Mon Oct 28, 2024 2:27 pm
Welcome to StarWind Forum. You can't exit the maitnenance mode while its replication partners are down.
