Migration Vmware to Hyper-V
Lehn_MR
Tue Dec 10, 2024 6:21 pm
I have a problem during the boot with a VM after converting it from Vmware to Hyper-V.
The machine is a Red-Hat 7.5 and this following erreurs display :
/dev/mapper/rhel-root does not exist
/dev/rhel/root does not exist
/dev/rhel/swap does not exist
I have already tried to regenerate the dracut to solve the problem but it doesn't change anything...
Below the command that i've tried :
 dracut -f -v --regenerate-all
I've tried to add the following parameter in the /etc/dracut.conf :
add_drivers+=" hid_hyperv hv_utils hv_vmbus hv_storvsc hv_netsvc"
But it doesn't change anything too
The rescue mode start without any problem.
Can you help me to solve this problem please?
Tue Dec 10, 2024 8:20 pm
Welcome to StarWind Forum. Can you please convert an individual disk and recreate the VM using that disk?
Use repair mode checkbox if possible.
Lehn_MR
Wed Dec 11, 2024 10:05 am
Thanks for your answer.
I tried your method but I had the same result during the VM boot.
During the conversion, I checked the Repair mode but it didn't work and returned an error.
Do you have any others ideas ?
Wed Dec 11, 2024 11:47 am
You are always welcome!
Do you have VMware tools installed into that VM?
Lehn_MR
Wed Dec 11, 2024 1:46 pm
Hello
Yes, VMware Tools is install into the VM.
Wed Dec 11, 2024 2:14 pm
Thanks for your feedback.
Can you try uninstalling them prior to conversion?
The error you point out seems to be some sort of a driver mismatch.
As a last resort, you can try converting the VM to OVF and moving it to the destination.
Lehn_MR
Fri Dec 13, 2024 8:30 am
I tried too but it did'nt work too, the same erreur appear during the boot.
To solve my problem, I reinstall from scratch the VM directly in the HyperV environment and everything work now.
Thanks again for your help
Fri Dec 13, 2024 2:52 pm
Sorry to read that there was no simple workaround.
Thanks for sharing your experience.
