Physical Windows server 2008 sp1 conversion
ashand
Tue May 13, 2025 1:40 pm
Wondering if there was a version of the converter that supported a windows server 2008 SP1 machine as its source, and if so is it still available. Its a physical server that is dutifully working away, but its on borrowed time. I can see the current converter is Windows server 2008R2 or later which this is outside.
Tue May 13, 2025 1:55 pm
Sadly, no P2V for the 32-bit version anymore. Try older versions of disk2VHD.
ashand
Thu May 15, 2025 2:00 pm
Thank you for your response yaroslav. I'll try your suggestion.
Thu May 15, 2025 3:00 pm
You are welcome.
Good luck with your project!
capina25
Sat May 17, 2025 4:04 am
I see Microsoft's Disk2vhd as a potential option for older systems as well that you might want to look into.
