Is it possible to mount starwind files locally?
tys
Sat Mar 24, 2007 6:34 pm
I'd like to know how to mount the image files locally.
I have 5 MSSQL servers. My plan is to let servers to create a dump on iSCSI volume(because MSSQL needs "physical" disk volume for dump location), then take a backup of these datas as windows files.
Because of my company's rule, backup shouldn't be a image file but windows readable files.
I'm going to attach a big size of HDDs to Backup server which running Starwind, means work as iSCSI target for MSSQL servers dump location.
If I share the iSCSI volumes on MSSQL servers to take a network backup, operation is will become very simple.
However this solution cause a redundant network data flow as follows.
[dump] MSSQL --iSCSI--> HDD
[backup] HDD --iSCSI--> MSSQL --IP--> BackupServer
The ideal data for the backup process is to open image file as real data loclally(not through iSCSI protocol) then take a backup.
If someone has idea. Please let me know.
tys
Sat Mar 24, 2007 7:46 pm
Configure any iSCSI initiator to connect to StarWind thru the loopback. Would work just fine.
tys
Sat Mar 24, 2007 8:18 pm
Thank you Anton,
So how the following path is changed?
I don't really understand why loopback helps the situation.
And how to change the initiator to loopback?
If MSSQL has 2 NICS which is for normal LAN(100Mb) and the other for iSCSI dedicated(Gb), loopback still helps?
Sorry for many question and thank you for your support.
tys
Sat Mar 24, 2007 8:31 pm
Run StarWind locally and connect you 127.0.0.1 to get loopback connection.
tys wrote:Thank you Anton,
tys
